跳转到主内容
4英寸屏幕;多种颜色可选;共发布三款型号;闪存容量:16、32及64GB
331 个问题 查看全部
My iPod has water damage, it works but screen is black
I dropped my ipod in the toilet, took it out straight away, dried it and carried on using it. I didn't know that your meant to power it off to not cause any permanent damage after a few minutes the screen started flickering and the brightness randomly changed. I left it to charge for the night, I woke up the next morning and the screen didn't work. However, I could still use it as the touch still worked and the ipod seemed to be working fine. I could play music and turn on games but I had to guess what I was pressing. I'm not sure if this is any easy fix? Maybe I just have to replace the LCD and digitizer? Please help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
''iPod needs opened up and cleaned with ISO alcohol it's the corrosion that causes the worst damage in water damage ..
Clean it then reassemble and access the damage again if still black then a new screen must be tryed
这个答案有帮助吗?
得分 0
1条评论:
I honestly did the same thing and it was working fine but it started flickering and it turned off but it works and I have to know what I am touching like I'm blind
完成的
添加一条评论
添加你的答案
Karolina 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 723
