跳转到主内容
日本汽车制造商斯巴鲁的修理和支持指南。
117 个问题 查看全部
Why is rearview mirror compass display very dim on 2009 Forester?
The mirror compass on my 2009 Forester is intermittently very dim/out and at normal brightness.
Although lately it is mostly so dim as to be unreadable, even at night. From what I understand this is a fairly common problem on this and other Subaru models.
Is there a fix I could attempt?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
same problem here and mine is completely gone now. also Forester 2009
完成的
Same here, mine stopped working two years ago, no dimming adjustment and no compass it is a 2009 Forester. also recently my drivers seat collapsed, near the door. I called Subaru of America, went to the dealership and they are putting in a NEW SEAT FOR FREE. Apparently this is very common. Should be a recall. We already had to have both my husbands brakes in his 2008 outback replaced and also mine. We went to merchants to do this and they said the braked needed to be replaced because either the drum or rotter was so thin it warped. What is up with these Subaru s? just lately my Nav got stuck at tilt position and was heating up to very hot. I had to full the fuse, now I have no radio, no Nav no cd player, no clock, no outside temp and no miles per gallon showing. I have 45.000 miles and I don't think I will ever purchase another Subaru!
完成的
2011Subaru Outback: rear view mirror is dim and blurry especially at night. Very distracting and makes it hard to see what is behind you!
完成的
添加一条评论
2个答案
I also have a 2009 Forest with a mirror that's been out of order for over a year. Is there a fix for this other than replacing it? like a fuse or some button I'm not aware of?
Sorry Netbiz1 I have no answer for your question but I too have that same problem, I was told at the dealership while having a recall issue fixed that it would have to be replaced for 300. That's ridicules. I was also told I needed front and back brake work also my drive belt had a crack in it. They just happened to feel the need to check my brakes without my asking. Wonder why.
Same day I took it to merchants auto and it only needed front brake work at less than half the cost that the dealership would charge also there was nothing wrong with my drive belt. My husband used to work at a Subaru dealership and that's how they do business by Telling customers they need something that they don't. Nice!
So that leaves me wondering if our rear view mirrors really have to be replaced or is it something so simple to fix.
So many recalls on everything else and of course my warranty is up. go figure.
这个答案有帮助吗?
得分 0
1条评论:
Also recently my drivers seat collapsed, near the door. I called Subaru of America, went to the dealership and they are putting in a NEW SEAT FOR FREE. Apparently this is very common. Should be a recall.
just lately my Nav got stuck at tilt position and was heating up to very hot. I had to pull the fuse, now I have no radio, no Nav no cd player, no clock, no outside temp and no miles per gallon showing. I have 45.000 miles and I don't think I will ever purchase another Subaru!
1 minute ago by mary
完成的
添加一条评论
Yep, reflow the solder on a couple resistors on the board:
http://forums.nasioc.com/forums/showthre...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
the fixer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 4,541
