跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
Why won't Dual Drive (1 TB Seagate SSHD) format?
I purchased the dual drive optical bay converter with a 1TB SSHD. All the hardware went into the laptop no problem. I am having an issue formatting the SSHD in the optical bay. I am using Disk Utility on Mac OS X 10.9.4. The drive easily formats to MSDOS and ExFAT formats, but fails when formatting to any Apple formatting system. What am I missing? I tried to use the Seagate drive software, but it is Windows-only. I've also tried partitioning over the current partition. No luck. I can partition to free space with no issue. Just not able to create an Apple Extended format partition.
Disk utility error:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Try deleting all of the partitions and try again.
Can you give us the model number of the Seagate drive you got.
这个答案有帮助吗?
得分 1
3条评论:
I have tried deleting all of the partitions to free space but that doesn't work either. Using the erase part of disk utility only works when erasing to MSDOS or ExFAT formats. Here is the link to the drive I bought:
[关联产品丢失或禁用: IF107-122-2]
It says that it should be compatible with the model MBP I have.
完成的
For clarification, I think the seagate model number is "ST1000LM014" (visible in the close up image on the product page).
完成的
This model has an issue with the higher speed SATA HD or SSD in the dual carrier. Here's a note on the issue from OWC Data doubler. The seagate drive you have is a SATA III (6.0Gb/s) while this drive can match to SATA I or SATA II I/O speeds the system is telling the HD it can run at SATA III so you get into a bit of a mess. I am surprised you can create FAT32 or ExFAT partitions with this drive. The older version of this drive could work here as it's I/O is SATA II. OK, what to do? I would try setting up the drive externally to verify things. If it worked that way that proves the issue. The other option here is to swap the drives around if your Apple drive is SATA II, more likely it's SATA III so while it may appear to work you could encounter corruptions.
完成的
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 2,542
