跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
black screen,no backlight, connects to itunes.
After liquid damage.. cleaned logic board, replaced battery/lcd digitilizer.
however screen remains black with no sign of backlight either. I can sort of see slight blackness on the lcd logic board component but wouldn't have thought enough to prevent the screen to not be working plus I would still have the backlight on, and its component is fine. ive checked that its seated in properly into logic board etc.
I can connect to tunes and battery is charging etc, it will vibrate when using the mute button.
would this possibly have anything to do with proximity sensor issue, (on/off button stopped working before the liquid damage) or lcd/digitilizer faulty or logic board?
Thankyou for any feedback
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hello it's possible that the screen is dead and a replacemnt will sort it but with water damage you just don't no
这个答案有帮助吗?
得分 1
2条评论:
Thankyou for responding. I shall try another new screen and hopefully that solves the issue.
完成的
If the new screen doesn't work then you no it's the problem with the lcd pins that are a bit black
完成的
添加一条评论
添加你的答案
Calder 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 184
