跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Why is my ringer not working?
Hello,
I have an iPhone 5S and after I sent it to a screen repair I have an issue that every time someone calls me I can't hear my ringtone. But when I press on the Settings to hear my ringtone it works well.
What should I do?
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
As you can still hear your ringtone via Settings that proves that your speaker is working fine
Did you try to reconfigure your ringtone? Did you go to ringtone management and chose a ringtone ? Or what did you do so far ?
Update
Try to clean the charging contacts with some 60% ethanol (alcohol) and cotton, which has 90% chances of solving your problem
这个答案有帮助吗?
得分 0
3条评论:
Yes, I tried changing ringtones and using custom ringtones but nothing worked. I even tried restoring it.
What do you mean cleaning the charing contacts? Does it require from me to open the cell phone?
完成的
No, all you need to do is to clean out where the charging cable is plugged in with alcohol, you don't need to take the phone apart. Something (dirt, etc) could be shorting out some contacts there that could make the iPhone think it is docked and to play the ringer sounds to the dock speakers.
完成的
Oh okay, how do you suggest me to clean it? I mean its very small how do I insert there anything?
完成的
添加一条评论
添加你的答案
Mor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,536
