跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Microphone and earpiece not functioning in calls. Intermitten.
iPhone 4 GSM AT&T. I have already replaced the charging port once with an OEM part. It is not a service issue as it works perfect in another iPhone and I have switched SIM's and reprovisioned.
1) The microphone works 100% of the time in Voice Recorder.
2) Every now and then (about 1/3) when a call is made the speaker phone button will be white as if its already turned on.
When this happens, you cannot adjust volume in the call (press volume buttons and nothing appears). I have tried tapping the speakerphone button off and back on. No sound or microphone at all, doesn't matter if speaker on or off.
3) The other 2/3's the call is made fine and the microphone and earpiece work and the speakerphone button is not white as if turned on and the volume adjusts.
I'm thinking possibly noise cancelation microphone (power button flex?) or a software glitch. I have not tried a restore yet, only a update, just looking for some possible input.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
I have a similar problem both ear speaker and mic won't work. I've tried replacing both but still the same. Also mic works in voice recorder
Would like to know a fix
这个答案有帮助吗?
得分 0
1条评论:
Is it intermitten on calls, or is it every call you make?
In the next week I will be trying the noise cancelation microphone (replacing the power flex ribbon) and a DFU restore. I will let you know if I have any sucess. Was just hoping for someone on here to be like "Hey, I had that problem... This fixed it :)" lol
完成的
添加一条评论
添加你的答案
Matt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 69
