跳转到主内容
加入维修社区 - 创建账户
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
iPad Mini digitizer replacement going terribly wrong.
After finally getting my new digitizer, I removed the old one successfully getting the digitizer off the front. When I started unscrewing the lcd, two screws came off fine. These two screws were at the top of the display. The two screws at the bottom however were not coming off so easily. My dad finally got them off after tinkering with them for about 30 minutes. Next, the lcd would not lift as easily as stated here and on multiple guides and videos! So my dad went to take a break and I go over to see if the lcd is still working. I pushed the lock button to find what looked like a crack on the lcd along with a very glitchy and unreadable display! iFixit said "After dispatching the four screws securing the lcd, we were able to lift it.". A few YouTube videos showed the guys lifting the lcd onto the digitizer and moving onto the metal plates! Absolutely none of the videos or guides mentioned a lcd that won't lift up! Please someone explain to me why none of the guides or videos I watched had these issues?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
The LCD is super thin and is stuck down with adhesive on each side my guess is you have stressed the LCD and broken it ..
It's says on step 33 that the LCD is stuck to the metal frame so it was telling you..
这个答案有帮助吗?
得分 0
2条评论:
The should have said that at the step where the lcd was lifted. Our lcd never lift like they described. This will be the last time I will replace something like this myself. Can you give me your email so I can send you photos of this thing?
完成的
Irepairiphones100@gmail.com
iPad mini is the most difficult to repair of all idevices
完成的
添加一条评论
添加你的答案
Rhett 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 230
