跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1234 个问题 查看全部
Salt water on dock connector
My iPhone 5 got splashed with salt water.
It still works, but a message about compatible device keeps displaying, which leads me to believe that salt water got on the dock connector.
I powered it down. Any suggestions on what to do next?
My wife suggested swabbing the inside dock connector with rubbing alcohol. Would that work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
it would defiantly help, it sounds like the contacts are getting shorted out, i would recommend a higher percent alcohol like isopropyl witch is 99% + alcohol, drys better as it has less water than standard rubbing alcohol, if that doesn't fix it you could try a new charger port
这个答案有帮助吗?
得分 1
添加一条评论
swap it quick, the sooner the better... make sure it's dry when you plug it in.
这个答案有帮助吗?
得分 1
4条评论:
Thanks, Michael and iwillfix. I'll do that next.
完成的
no problem. don't wait to long, salt water damages the copper pins...
完成的
Thanks, I swabbed the contacts with denatured alcohol and put it back into the bag of rice. I'll give it a try tonight to see how it runs after 48 hours of being in rice. I'll also open it up to see where there might be salt damage if salt water got inside beyond the contacts.
完成的
Don't waste your time by putting it in rice. That doesn't really help.... you could open it up to check for damage. But i would already try if it works..
完成的
添加一条评论
添加你的答案
glenn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 9
总计 124
