跳转到主内容
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
Why won't my washer start?
it was in the middle of a load, its unbalanced. took all clothes out got back remaining time hit start just hums wont run
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
I tried everything light is on but it won't kick on any suggegted
完成的
Same thing, please help
完成的
@christinas41883
What is the model number of the washer?
完成的
添加一条评论
2个答案
已选择的解决方案
Unplug it and let it sit for 5 minutes. This will allow it to re-set. Plug it back in and see if it works.
这个答案有帮助吗?
得分 1
2条评论:
this only cleared the error code but return when i tried to start again.on another site was told to blow through pressure hose.i restarted a cycle it ran fine until the spin cycle where it just hummed once again and brought up ld code once again.any ideas?
完成的
Error code? Don't you think an error code would be useful in diagnosing your problem?
完成的
添加一条评论
Sounds like a motor spin or clutch problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
thunder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 7,746
