Front camera blurred. Freezes. Resistor value. SOLVED!
Hi.
Since i had to disconnect and reconnect the front screen several times, i unfortunately broke one of the resistors of the logic board.
Does anyone have the schematics for an iPhone 5, so i can get the correct resistor value. Thank you.
Okay. I solved this one. Just solder the two points... simply short circuit. Is works.
3条评论
由 Klaus M 完成的
Can u shows the picture of the soldered place?
由 MraZ 完成的
See the red circle on the attached picture in post #1. Beware that the footprint is very small. You will need some kepton tape or a steady hand to do this :)
由 Klaus M 完成的
