跳转到主内容
加入维修社区 - 创建账户
PowerBook won't start with installed battery
Hello
My Powerbook won't start with installed battery.
If the Battery is not installed the powerbook starts normal.
I did all resets i read (PMU, SM*, etc.)
With a new battery it is still the same.
Wich part of the Book is broken?
The power supply is noise *feeep* when plugged in but seams to charge the battery.
PRAM?: With no installed battery it forgets the date after a while with no power cord plugged in
DC-IN Board?: Is that responsible for power management?
or the logic board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Well you do have a couple of problems here:
First you'll need to replace the PRAM battery if your model has it. Here's the guide to get to it: PRAM Battery & USB Board Replacement. Some of this series had a clock chip which had it's own battery internally on the logic board.
I do think you have a logic board issue with the charging circuit. The DC-In board does not have any of the charging logic on it. This could be a big job to diagnose and repair.
This system is quite old. I think your money & time would be better spent on a newer system. Don't get me wrong here in its day is was one !@#$ of a system! I had the titanium version for quite a few years.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
nudge 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 242
