跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
HELP! iPhone was drowned, Home button stopped working.
Last morning, I dropped my Iphone 5s into the water for 1 second.
I turned off it and started to disassemble it.
The water even couldn't get into the motherboard side.
Everything seemed fine except the Home button.
1. My Iphone was dropped into the water
2. The water even couldn't reach to the motherboard.
(Only one of three water indicator turned to red)
3. Everything seemed fine except home button.
4. It's not working, but the touch id function is working.
What should I do with it...?
I don't want to loose both touch id feature and home button function...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
check the home button connector and the charger port flex slot it plugs into for corrosion, and cleaning that with isopropyl alcohol, if that doesent work next step would be new charger port , final step is new home button, but a new home button will lose touchid function no matter what
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kimbell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 95
