跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
Why isn't my optical drive working?
I have an iMac 8,1 20" 2.4Ghz with a Matshita DVD-R UJ-875. The drive would not accept discs, so I gave a disc a little push and the drive pulled the disc in. Now, there is no disc seen in the drive (no media) and the hardware test passes. Also, every so often when the iMac is in sleep, and at startup, the drive makes a noise like is trying to load a disc. I don't know if I should pull it out and remove the disc or replace the drive, or...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
See if you can get a CD/DVD cleaning disk. These have a small brush on the surface to wipe away any dust that has collected on the readers lens. If your careful you might be able to blow off the dust with a small burst of can'ed air. Just be careful here as you don't want the liquid to spray out as that will damage the lens. Aim the straw in the exact middle of the slot.
If that doesn't fix it you'll need to open the system up to replace it. Here's the IFIXIT guide on how to do it are you up to the task? iMac Intel 20" EMC 2133 & 2210 Optical Drive Replacement.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ryan Crabtree 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 161
