跳转到主内容
Also known as the GS70 Stealth, this 17" gaming laptop was released in summer 2013 by Micro-Star International. Identified by the model number MS-1772.
20 个问题 查看全部
How Do I Factory Reset My Laptop
I Forgot My Password Since I Had Bought Anothe Laptop After Thinking This One Was Broke But I Fixed It But I Cant Remeber The Password So How Can I Erase And Restart My Laptop Back To Factory Settings
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
5个答案
最有帮助的答案
If you have Windows 8 / 8.1 installed, you can use the built in recovery feature of the operating system.
Go to control panel -> Recovery -> At the bottom there is a link which reads 'If you are experiencing problems with your PC...' and then 'Remove everything and reinstall Windows'. This will delete everything and do a full reinstall. It should use the recovery drive available on your laptop to restore to factory defaults.
这个答案有帮助吗?
得分 1
添加一条评论
Yes you can by pressing F3 when starting up
这个答案有帮助吗?
得分 0
1条评论:
with F3 i just get into the bios, but no option to reset
完成的
添加一条评论
after holding f3 it asks about resetting windows but only restarts my comp no option for reformat wtf?
这个答案有帮助吗?
得分 0
添加一条评论
Press f8 untill it says repair.my.computer
Then look for factory restore option
这个答案有帮助吗?
得分 0
添加一条评论
Fogot password on laptop dell brand
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dante Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 14
总计 28,435
