跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Why is there no sound?
I got a new iphone which works perfectly. I set it up and put in my SIM card. Everything works perfectly . A couple of hours later I discover that there is no sound coming from the phone. I restore the phone, check the buttons. Still no sound. I then change SIM cards in the phone and the sounds never goes away. Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论:
I think it may be caused by the type of charger I am using? Is that a possibility?
完成的
添加一条评论
2个答案
"and the sounds never goes away"
What does it meen?
2 options..
1) change the speaker
2) check your silent/vol switch!!
这个答案有帮助吗?
得分 0
1条评论:
When I change the SIM card the sound works perfectly. It never dies out.
完成的
添加一条评论
When u press volume up or down does it show it going up or down or just say volume
这个答案有帮助吗?
得分 0
1条评论:
At first it did. Now it works normally
完成的
添加一条评论
添加你的答案
Silas Brou 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 4
总计 156
