跳转到主内容
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 个问题 查看全部
iPad 2 Logic board replacement
If I an activation locked ipad 2 and I cannot get in contact with the previous owner, will replacing the logic board bypass this so that the iPad isn't connected to the previous owner anymore? I have a broken/unusable iPad 2 for parts and I could try to swap the logic board if you guys thinks this will work.
I think the IMEI number is connected to the previous owner. When you connect your iPad 2 to iTunes, iTunes will send the IMEI to Apple server to check if it's connected to an account. IMEI is usually buried in the logic board. So, I think, if you change the logic board then you will get new IMEI number. Please correct me if i am wrong.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Changing the logic board will solve your problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 264
