跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Vertical white and yellow lines after fall/drop
Phone has horizontal lines on screen after I fell and dropped it. they are primarily on the left side. I can use some functions of phone, but not some keys etc. on the left. texting/typing wont fully function.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
You will need a new screen fitted to the device to fix this issue, the issue has been caused by blunt force as the phone fell and hit whatever it landed on and has damged the lcd.
if you are doing the repair yourself do not buy the cheapest screen on the market try and by original or oem screen.
Heres a guide for replacing the display - iPhone 5前面板替换
这个答案有帮助吗?
得分 1
添加一条评论
Alyn is correct on replacing the the display. Locate a reliable vendor with quality screens. You won't find any OEM screens as Apple does not sell them through any vendor. Also, don't buy a "used" screen, even if it is an original off another iphone. You have no idea how many hours are on the screen. Buy a new assembly in as good quality as possible. I recommend Mobile Defenders.com
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
wrenskk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 9,925
