跳转到主内容
修复你的物品
维修的权力
商店
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1972 个问题 查看全部
Why it`s over heating?
i found somthing but not workin`
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
There could be many reasons why your iPhone is over heating but the most probable cause could be water or moisture damage.
if a component on the logic board has been damaged this could also make the device over heat.
please give a little more information regarding the over heat issue.
when does it happen?
Is it charging at the time?
Has the device ever been repaired?
Has the device ever been water damaged?
完成的
添加一条评论
1个回答
iPhone's tend to overheat when you are doing 'heavy duty' activities. Try closing all of your applications (double tap home button to see open apps, if you have iOS 6 tap and hold on an app to show the 'x' symbol then press the symbol to quit the app. If you have iOS 7 then just slide each 'app preview' up). Also if you have a lot of applications using location services it may be the reason for why your phone is over heating. Try to minimize those as well.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
julia21 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 58
