跳转到主内容
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 个问题 查看全部
Why is my laptop overheating and shutting down randomly?
The temperatures on my Macbook Air get pretty hot (80 degrees Celsius +) at mid-heavy use, like streaming videos online or opening iPhoto, causing the fan to run at 4000~5000rpm. When hot, the laptop will also shut down when I lift it up from a surface.
After doing SMC resets and running hardware diagnostic tests (which all of the components of my laptop passed, no problem!), I'm beginning to suspect that the thermal paste and heat sink needs replacing. Someone else I talked to suspects that I need to replace the fan. I would just like to be a bit more confident about which part to replace before taking my laptop apart (that is, if this is something I should be doing.) Does anyone have any idea?
I'm resorting to this because the previous two Genius Bar experiences I've had concerning this issue have been largely unhelpful; the first guy just dusted out the fan, the second guy told me that I had to replace the logic board entirely!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
I would recommend downloading a temp & fan monitoring app like this one: Temperature Gauge Pro. It will help you identify the area that needs attention. If you see something odd snap a screen shot and post it here for us to see.
Also Apple just released an updated firmware to address some startup fan issues MacBook Air update solves issues with sleep and blasting fans Read more at http://www.cultofmac.com/288357/macbook-.... But no sooner did they post they pulled it back ;-{
Here's a link to the current firmware the link will explain how to check it: EFI and SMC firmware updates for Intel-based Macs
Keep your eyes open of a newer one in the next week or two.
这个答案有帮助吗?
得分 2
添加一条评论
Turn on the Activity Monitor, if the CPU is at idle or almost idle, the temperature is too hot to be normal. But if the fan only runs high during heavy workload, it is normal.
From your description, the performance is consistent with the normal performance of this machine apart from shutting down. It is a hot one so you shouldn't be surprised to see 80 degrees celsius+.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
tsarinelle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 5
总计 5,834
