跳转到主内容
加入维修社区 - 创建账户
型号 A1059 或 A1099 / 20, 40, 或 60 GB 硬盘 / 触控转盘
What I thought was a battery problem...
Might not be. Definitely had some issues with battery life. But now with new battery, still getting same "low battery" signs on display. iPod often does not take charge from wall and only occasionally works with iTunes via USB port. Granted I have an older Mac at 10.3.9 and the last iTunes that works with that OS, but same cable, computer, and USB work with an iPod nano. When connection to wall or computer does work, no charging takes place - yet "green" battery blinks as if it is being charged. When connected to iTunes, gets frozen in downloading of playlists. This freeze does not stop and renders iTunes in need of Force Quit. Will order Logic Board. Unless someone has a better idea than simply junking it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I would first check the dock connector in- and outside for possible fluid damages or lint/dust/dirt
since the contacts are often exposed to any kind of humidity - they could have bad contacts - maybe you should get IPA (>90%) and a soft paintbrush, clean the dock connector and try it again.
check the logicboard for possible fluid damages (white/greenish substance on the logicboard - if there is something like that - clean it carefully like the dock connector)
maybe it helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
marcsar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,017
