跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
295 个问题 查看全部
Any luck on replacing a Dock Connector?
Attempted twice and afterwards the device fails to initialize that the charger has been connected.
Anyone had any luck with replacement?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Has anyone been able to successfully replace an iPad Air dock connector?
Thanks
完成的
添加一条评论
3个答案
最有帮助的答案
The dock conector that was replaced is original or at least a good quality?
Can also be a component that is responsible for identifying the cable does not work in this case would be very hard to fix it ... unless there the same component on the iPhone 5/5S and then to replace it buy soldering
这个答案有帮助吗?
得分 1
1条评论:
The dock connectors were purchased from etrade supply, so I would consider them pretty good quality. The solder tech I had replace the dock connectors is one of the best soldering techs I have seen with over 20 year experience. I inspected his work under microscope and the soldering job is flawless.
I have received the cable error message a few times when connecting the lightning cable to the device. I have ruled out cable brands as I have tried OEM, MFi certified, and other ones; still comes up with an error message.
Which component do you think I should consider looking into to replace?
Thanks,
完成的
添加一条评论
www.mycelcare.com in dubai.. i am their client too. trustworthy centre
这个答案有帮助吗?
得分 0
添加一条评论
Fault does not recognize the cable reminds me of the problem of the iPhone 5 u2
U2 responsible for identifying the cable and serves as a kind of starter while charging, try to search the component is similar but the problem that this device dont have scheme
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,407
