跳转到主内容
First set-top box powered by Google TV.
7 个问题 查看全部
The fan become quite noisy. I assume it should be replaced?
The teardown you present appears quite easy. I want to replace the fan as it has become noisy. Are there any pitfalls I should know about. Do I have to go to logitech for the part?
Thanks
Robert
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
最有帮助的答案
Hey mate. From having a search around, I discovered it is a common problem, and if you wish to replace the fan, its part number is BSB0705HC, -8Z02 apparently, but you can't obtain it through Logitech and need to obtain it via 3rd part. If want to try fixing it first, you can try removing the fan, dismantling it and cleaning any dust/debris from inside of it. Also clean any ducting and the heat sink its self as normally, nosy fans are due to being over dusty or over worked.
Also, this link contains a bit more information; http://forums.logitech.com/t5/Revue-and-...
Hope this was of some help
这个答案有帮助吗?
得分 1
添加一条评论
Thanks zakk,
Cleaning sounds sounds like a good first. Found excellent teardown instructions on ifixit also have contacted Dela Electronics for part.
Robert
这个答案有帮助吗?
得分 0
1条评论:
Its quiet alright mate, I'm glade i was able to help.
完成的
添加一条评论
I fixed mine by making rubber mount for the fan using wide rubber band cut to fit between the fan shroud & the plastic case. Also used WD40 to lubricate fan shaft.
Also when unit is not in use I unplug it and bypass the unit, connecting the cable box HDMI direct to TV.
Shame the unit is not provided with on/off switch & HDMI bypass.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 9
总计 827
