跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
everything is working fine except from the home button
After replacing my iPod's front panel everything is working fine except from the home button, it is unresponsive.
If I press the switch directly it works, but not if I use the button! May the button have been damaged during the repair?
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Under the button you see a spring. Sorry don't have a picture right here. The button only shorts this spring so the two gets contact. Try (very carefully since it can easily break) to lift up the spring so it is easier to short it. I remember I had the same problem and the spring was broken so I had to lift up what was left so it came in contact with the button. Don't remember if there are two springs but you see what the button is supposed to make contact with. Hope it helps!
这个答案有帮助吗?
得分 1
1条评论:
Ummm.... I can't see the spring... iPod touch 4th Gen is supposed to have it? :S
完成的
添加一条评论
It's not a spring it's a little black peice that sits up slightly it's common for this to break off
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
luciacossio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 83
