跳转到主内容
The first 8 inch Android tablet by Samsung.
50 个问题 查看全部
Indicator says charge low when it is not
After short use of Tab, indicator goes down very quickly and tells me to charge, when I know it shouldn't need it. If I switch off and back on indicator goes back up to a more believable level. I can carry on using and then same thing happens again. I always wait until battery very low before charging fully.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Most likely you are using the charger is not original or one of the amps not suitable for Galaxy Tab.
Or that the problem is a bug, then it should update software or restore the factory default values​​.
这个答案有帮助吗?
得分 1
1条评论:
Thanks.Charger is original which came with the tablet. However I have run battery down until would barely switch on and recharged overnight. Not had same problem yet. Tablet still under warranty so will return if happens again.
完成的
添加一条评论
添加你的答案
Elaine McLocklin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 489
