跳转到主内容
Why is it malfunctioning after replacing the battery?
I have replaced the battery as directed. The display lit up, with a blank screen upon powering up...but that's all. After approximately 2 minutes it beeped twice, and there were dark bands on the lower area of the LCD display. Now it just beeps every 2 minutes.
After being plugged into a charging dock for 30+ minutes the lower half of the display has alternating bands of black and dark grey, and is still beeping twice every 2 minutes.
I used a soldering iron that was not calibrated...might I have fried the pcb?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
The problem you describe is due to damage to the screen.
The beep you describe maybe that replacement battery that is not good ..
If I were you I would try to change the screen display, do not think that damage to the PCB because it lights up.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
maryellenhart 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 9
总计 313
