跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for phones produced by the South Korean phone and tablet manufacturer, Pantech.
Pantech Renue P6030 unresponsive buttons and vibrates with no power?
I had my phone in my pocket when it started to rain. I was completely soaked but my phone only showed water on the edges of the phone. The phone now vibrates constantly or sometimes on and off. It even vibrates while the power is turned off. The only way I can get it to completely stop is to take out the battery. The keyboard no longer works as well as the volume buttons. The power button is the only button that works. I am able to text using the touch screen and also able to make calls. The entire time I'm working on the phone, it is vibrating. What happened and is there a way to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
Power off the device immediately. Do not charge the device. Take the device apart and unplug the battery. Remove the components and submerge them in Isopropyl alcohol for 3-5 hours. Remove them from the alcohol and allow them to sit in front of a fan overnight to dry out, longer if necessary. Then put everything back together and see if there is a change.
这个答案有帮助吗?
得分 0
添加一条评论
I am unfamiliar with taking apart phones. There weren't any videos on YouTube that helped me out with my phone. Do you know how to take the phone apart or do you know of any videos related to my phone? Will I need to special tools for this process? Could I just submerse my entire phone, without the battery, in the alcohol?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kendalltp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 659
