跳转到主内容
Released 2007, Identified by brand and model stickers, and serial number R4416.
How do I lengthen the front post to raise the handlebar?
The clamp holding the front post will not let loose with the nut loosen. How do I get the post freed from the clamp to raise the handlebar?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
You can try to heat it with a heardryer and then quickly add force to the steer (does not really matter in what direction). Have you already tried WD40 (or similar lubricant with corrosion-soluting components)? Sometimes a nice bump with a hammer (and a piece of wood on your stear to protect the paint) helps.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Lawain 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 684
