跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
问题已关闭
Error 14 after housing replacement
I have a 5s and the rear housing was bent so I ordered a new one and followed Ifixit repair guide to replace the housing. I had reset the iphone prior to the replacement so it was like a new phone. Once i replaced the housing i plugged the charger in and it started up fine. then after a few minuets it rebooted and then stuck on the apple logo and then the screen goes blue and it restarts and repeats. I tried to restore the phone and it starts to restore the phone and again the screen goes blue and itunes shows message Error 14. Is this due to something i missed or done wrong during the replacement?
Thanks in advanced
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I think I have solved the problem. I stripped the phone down and double checked my steps and I think it was a fault of my with the ground to the logic board. after reseating that it seems fine now has restored fine.
完成的
添加一条评论
2个答案
Try to do the restore on another computer.
这个答案有帮助吗?
得分 0
1条评论:
I have now tried it on 2 laptops 1 mac 1 windows and tried 3 different leads in 5 different USB ports and it still does the same always at the same point as well. Could this be a hardware issue?
完成的
添加一条评论
Your iPhone is will not coming back to life, you will need to take it to Apple for a replacement.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 207
