跳转到主内容
Micromax Canvas 2 Plus A110Q is a dual-sim Android smartphone by Micromax Mobile launched in May 2013.
12 个问题 查看全部
Does not charge if kept on?
My Micromax Canvas 110Q is just 7 month old and now it does not charge when phone is ON. After switching OFF the phone it will charge, but someties it shows low battery after full charging. Restarting again will show battery as 100%. I had installed DU Battery saver app from the start. Can it be the software problem and should I uninstall the DU app?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 13
8条评论
how did u fix it. same problem for me also
完成的
Above same problem here , my phone is micromax a110 canvas 2, it is purchased in 2013, charging problem when mobile is switch on but start to charge when it kept off.
please send me the sollution. Service center in Sangli (Maharashtra) also unable to solve my problem.
Please help.
Santosh Waghmare
7875969379
完成的
I am also struggling with same problem with Micromax Canvas A110. It charged only in switch off mode. If anyone got solution to this problem, please share
完成的
完成的
I have a same problem like above with my Huawei G mini which I used for last 1.5 years. Now it does not charge when phone is on but it charged if the phone is off. please help me with this issue.
完成的
显示更多的3条评论
添加一条评论
11个答案
最有帮助的答案
1. Download and install MTK engineering app from play store
2. Open it
3. Go to Hardware testing
4. Go to USB
5. Go to USB IF Test
6. In the first four options...do start and stop
7. Now go back and press on UART/USB switch
8. Here choose UART radio button
Now count 1....2....3....4....5... And your phone will be charging now
这个答案有帮助吗?
得分 15
21条评论:
You are Awsmmm Bro.
You just made my day ....:)
Thanks a lot this F**nin works (y)
完成的
It worked for me in Micromax canvas spark 2
完成的
It works TY Dude . and can you tell us how you got this idea ??
完成的
Thanks lot.. It is works.. Very nice..
完成的
Thank you bhaai its working..,Now just only one problem how to install new apps every time it showing error that insufficient storage.
完成的
显示更多的16条评论
添加一条评论
That would be my first guess, try uninstalling and let us know what happens.
这个答案有帮助吗?
得分 0
1条评论:
Did you see what happens when you disconnect the battery from the logic board and then reattach it?
完成的
添加一条评论
same problem here , i have not installed any saver app but facing the same problem.Mobile is charging in switch off mode only, what can be the reason please tell ASAP ?
这个答案有帮助吗?
得分 0
添加一条评论
same case with me on unite2 plz help;no batterysaver app or anything! hope it works after somet ime!
这个答案有帮助吗?
得分 0
添加一条评论
hi guys,
my micromax a110Q , 1year old.
Started hanging & auto on off.
After restoring factory set up & updating soft ware . its dead.
No charging, totally black screen.
can some body suggest a way out.
这个答案有帮助吗?
得分 0
1条评论:
I have installed in Canvas 2.2 and battery is not charging as usual, if you remove battery and put. Is it necessary to update mtk engineering tool ?
完成的
添加一条评论
Please help.
Santosh Waghmare
7875969379
这个答案有帮助吗?
得分 0
2条评论:
the same problem with me i could not charge my micromax a110q when is on and if i switch off my mobile and plug in for charge it become charge. please send your answer on my e-mail: suryapurbia1@rediffmail.com
完成的
Same problem with my micromax A110 from last 2 days. i also purchased in 2013. plz mail me solution on nchitikant@gmail.com
完成的
添加一条评论
This was firmware bug lately patch by micromax in new updates. Check new updates from micromax if updates not available then try to flash custom firmware but you have to root it before going further.
这个答案有帮助吗?
得分 0
1条评论:
Smith Can you tell me how to flash frimware and root micromax a110 phone I have the same problem of not charging when power is on.
完成的
添加一条评论
这个答案有帮助吗?
得分 0
添加一条评论
1. uninstall DU battery first.it sucks out your battery more.
2. Check out the charging port ..it may be filled with dust and lint...try cleaning it with a safety pin
[ NOTE: be careful not to damage the port ].
3. Now try restartin it.
这个答案有帮助吗?
得分 0
添加一条评论
Go to a Mobile Mechanic do not Spoil ur time here....
这个答案有帮助吗?
得分 0
添加一条评论
Hi, have you performed a battery recalibration? To be honest no one battery apps are good, they just cancel some logs from your device (in few words) Here is how to perform a battery recalibration.
How to calibrate a smartphone battery: Let the device reach 0% and let it shut down till you can not even turn it on
Connect the battery rechargerwall and let the device reach 100% battery without turn it on.
Once the device reached the 100% battery let it connected for other 2 hours (without turn it on)
Once the 2 hours are passed with the rechargerwall battery connected to the electricy, turn on your device for 20 min, after that turn it off.
Once you turned off the device disconnect the rechargerwall from the wall then disconnect the usb data cable from rechargerwall battery. After that reconnect the usb data cable to the rechargerwall battery and then reconnect the rechargerwall battery to the wall electricity
This operation should be repeated for 3 days in a row. Do not perform this operation more than 3 times in 2 months.
Let me know
这个答案有帮助吗?
得分 0
1条评论:
I have micromax canvas tab which now a days becing a problem it doesnt charge properly
If it is charged it goes complete dead
I hv to connect the charger nd then use
If i am onning also the flash comes later within a seconds it goes off y it is so and any suggestion for it
完成的
添加一条评论
添加你的答案
Sudipta Ray 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 14,280
