跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Touch ID not working after LCD replace
Hi,
I have 5s that screen already replaced with the new one, and now the touch id is not working.
sorry the operation was not successful touch id
after i restore, touch id menu is gone from Settings.
but, the one thing i know is. when i bought this phone from the previous owner, the lcd has already replaced too not from Apple, but the touch id is working.
so might be there's another way to fix it.
so confusing me because the previous owner of this phone is missing, i cant contact them.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
the touch id still original.
完成的
添加一条评论
3个答案
最有帮助的答案
if you haven't already tried, do a soft reset by holding the home button and the power/lock button until the phone turns off.
这个答案有帮助吗?
得分 1
2条评论:
Soft reset worked for me.
Tks alot!
Mat
完成的
Worked for me too. I switched on the phone with out connecting the home button after connecting it touch id did not work. But then i saw your post and did a soft reset all good nowww!!!!!
完成的
添加一条评论
Nothing to do with original owner or a replacement screen..
Make sure you have seeded the little touch id connector correctly again if it is then you have cause damaged to it when removing from old screen
这个答案有帮助吗?
得分 0
1条评论:
I mean is,
If the replacement LCD is causes touch id not working, so why the previous owner can use it, whereas he already replace it too.
because i have research, that is because LCD Replacement. my home button working properly, but not with the touch id.
完成的
添加一条评论
Did you yourself actually see this touch ID work, or did the seller just say it worked?
A new lcd shouldn't effect the touch ID, either the little snap connection is not fully seated, there's some lint/fibers in the connection to stop contacts fully touching. Or the cable has been damaged.
这个答案有帮助吗?
得分 0
1条评论:
yes, i actually use and see the touch id worked for a couple week before i do a replacement LCD.
完成的
添加一条评论
添加你的答案
Alvin Giovanno 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 14,744
