跳转到主内容
加入维修社区 - 创建账户
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
static image and colorful screen
The problem start two weeks ago, the screen started to fail but the problem it's getting more frequently, if I use my phone for 10 seconds the image get freeze, if I turn off and turn on the screen, it shows a colorful static image like old tv without signal, if I turn off the screen for a minute, when I turn it on again, the phone works well for almost ten seconds and get stuck again but is only de image, the phone continue working with the freeze or the colorful image
I read that it could be the the part "USB Port Dock Connector Mic Flex Cable" but I want to confirm before buy it
thanks in advance
Note: the second image is not mine, I use one found in a forum but it show the same problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
2条评论:
any solutions ?
完成的
yes, I fixed it changing the flex usb charge port
完成的
添加一条评论
4个答案
Left my Nexus 5 for about 10 minutes, took it up to check message and the screen was the same as the second picture. Tried rebooting the phone, however nothing seems to work nor does the rebooting screen comes up
这个答案有帮助吗?
得分 0
添加一条评论
My phone started showing that screen with low frequency, now if I keep the display on for one minute the screen show the static-y screen
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue. Looking on forums I found the problem. You need to replace the FLEX USB charge port.
I´m looking on ebay to buy one.
这个答案有帮助吗?
得分 0
添加一条评论
Have you fixed it...i have same problem...help
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
添加你的答案
Alexander Morales Sevilla 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 34
总计 2,584
