跳转到主内容
display on/off-sensor placement / clamshell mode
Hi .. I want my MacBookpro to run in permanent clamshell mode without needing to close the display. I thought I could just trick the open/close sensor system or so
any idea? where is that bugger, in the hinge?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
Located on the back of the right side of the keyboard, about in the middle.
It is commonly called a reed switch. By sliding a paperclip along the bezel bottom you can locate the magnet in the bezel. Placing a magnet on the top case in the correct position will "sleep" the display.
If this answer is acceptable please remember to mark it.
Good Luck,
N.
这个答案有帮助吗?
得分 1
1条评论:
Genius. Trying to figure this out for years. Even the IT guys I was working for didn't know.
完成的
添加一条评论
I have a MBP with a busted screen (backlight working). It's hooked up to a studio diplay that is configured as main monitor in system preferences. The MBP display doesn't do a thing now, neither open or closed. No need to trick any sensors.
这个答案有帮助吗?
得分 0
2条评论:
but is it still in the system prefs? i hate saerching for windows that are located on a second screen thats switched off
完成的
Once the external display is configured as main all windows are displayed on it.
完成的
添加一条评论
ok .. it seems to be in the screen on the right side of the camera and the little hook thingy that keeps the cover down. attaching a magnet there sends my MacBookpro to sleep
thanks machead3
这个答案有帮助吗?
得分 0
添加一条评论
Had this happen on an A1278; couldn’t figure out why. Magnetized USB connectors were the problem. Demagnetize them with something like this: https://amzn.to/2CEM4pJ
There are 4 strong N or S domains on the upper display border by the camera, starting about 2” from the outer edge of the display clamshell and ending about 3-4” inches in, on both right and left sides. This makes me think there’s either 1 or 2 clamshell sensors (hall or reed type) in the palm rest on either side of the trackpad.
pmset -g log:
Display is turned off
Entering Sleep state due to 'Clamshell Sleep' …
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kay k 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,270
