Screen randomly goes white after replacement
Hi, trying to fix my son's iPod touch 4 after he dropped it, smashing the touchscreen and denting the case.
I put everything into a new case, and fitted a new LCD and touchscreen unit. I tested without putting adhesive on in case I needed to do anything.
It worked for 10 minutes then screen brightened to white and ipod was unresponsive so I held power button until it turned off. It wouldn't turn back on and wasn't recognised in iTunes.
I had to let the battery go flat over several days, then plugging it into the charger brought up the charging symbol.
It worked for 2 days then while being used went white again. Won't come on again now so I'm leaving it to go flat again.
Has anyone had this odd random screen issue after a screen replacement? I don't know what to do next...
Thanks
2条评论
Thanks for the reply. While it worked for those 2 days, I noticed the battery went flat in only an hour or so of use. No shorts so will try a new battery and post results here.
由 Chappers 完成的
I did wonder if it might be because the screen is a copy. As for the copper tape, I don't recall any being on either of the two screen connectors. Which should have it, the uppermost connector visible when screen is lifted, or the one hidden under the logic board?
由 Chappers 完成的
