跳转到主内容
The Canon PowerShot A70 is a 3.2 MP point and shoot camera
4 个问题 查看全部
This camera takes blurry pictures.
My camera takes blurry pictures sometimes even though it's been repaired by the folks at Canon (Cmos sensor was replaced? Or that little sensor that sees the object). It needed an update so it was sent in. Now it takes a blurry picture quite often. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
最有帮助的答案
sounds like the auto focus isn't right.
when was the repair ?
why did you send it in for an update (the firmware is downloadable on canon's website)?
i would check the focus settings first, maybe the focus field has a wrong setting!
这个答案有帮助吗?
得分 1
添加一条评论
Does it focus right when you do macro shots? is there a difference if you are zoomed in and zoomed out?
When you sent it in to repair, it should be under warranty for a short period of time. I urge you to send it in again and report this as I am pretty sure this is a hardware problem and not software.
这个答案有帮助吗?
得分 0
添加一条评论
Recommend contacting Canon again. The CCD sensor may have failed again. Here's more info on the free CCD repair for the A70.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
amelnychuk 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 3,335
