跳转到主内容
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
455 个问题 查看全部
问题已关闭
Charging light stays on after charger has been unplugged.
As the title says, also, it turns off when you unplug the charger. It's been on charge since 12 last night and the charging light stays on once you unplug it while the 3ds is off. The light comes on when the battery is unplugged but the charger is plugged in. I recently changed the speaker flex and when it turns if it also pops.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
I had an issue with a family members 3DS. I allowed the battery to die completely, I then take the battery out and let it settle for about 5minutes before putting it back in, you should leave it to charge fully and it should help resolve the issue.
If this has helped you please vote the answer and accept it, if this hasn't helped please let me know so I can help you further.
这个答案有帮助吗?
得分 0
添加一条评论
I've just ordered a new battery. A bigger one, too. £3 on eBay! Bargain!
这个答案有帮助吗?
得分 0
2条评论:
That is a good bargain, I hope that I helped in any way?
完成的
Get a battery from Nintendo's website or further problems could occur.
完成的
添加一条评论
Charged up DS overnight, DS power is Off, unplugged DS from charger and charge light remains on, turn power on and off for DS, DS turns on showing full power and turns off normally, but charge light remains on whether it is on or off but DS has full charge... Any suggestions?
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 2,945
