跳转到主内容
7.9寸显示屏/型号A1455 /黑色或白色/发布/ 2012年10月23日/ 16/32或64 GB容量
30 个问题 查看全部
问题已关闭
Display dont shut down after TouchScreen Replacement
Hello, i replaced the Touchscreen of my broken iPad mini White. Now the iPad dont shut down with my Smartcover. I tested the Smartcover an another iPad mini and it works, but dont work with iPad mini New Touchscreen.
What is wrong?
With a second Touchscreen the Same :-(.
I hope you cant help me.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Make sure in settings the option is enabled
这个答案有帮助吗?
得分 0
添加一条评论
The smartcover function relies on a couple of SMD components that are on the home flex. Unfortunately, many of the third party supposedly "OEM" whatever that means do not have these components on their home flexes.
You'll need to buy a digitizer assembly that has an original quality home flex, or desolder and switch out your aftermarket home flex with one that is original quality.
I wrote a post about this that has the pictures so you can see what I mean:
post about different quality ipad mini home flexes
Also remember to transfer the magnets from your original screen---these aren't required for smart cover function, but they do help hold the thing up when vertical.
这个答案有帮助吗?
得分 0
添加一条评论
Hi,
I also answered this one through Facebook. I want to know if the ifixit aftermarket digitizer screen contains the original (or working) home flex. I want to order one to replace my broken screen.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 187
