跳转到主内容
The Dell Inspiron 15R laptop features a 15.6" screen, brushed aluminum finish and long battery life, plus a thin and lightweight design.
18 个问题 查看全部
Why Laptop is not on.
My Dell laptop is not turn on. When i press power button, button light on and off but laptop not turn on. Please help me. I already connect charger and check.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi,
- Check it with other charger
- Remove the battery and try to power on it only with charger (may be you have a bad battery)
- With removed battery and charger, press and hold the power button for around 30s. to reset the BIOS
- If you can, charge the battery on other laptop (may be you have a problem with the charger or the charging port)
If this not help you, you have a hardware problem.
Regards.
这个答案有帮助吗?
得分 1
添加一条评论
-It may from d motherboard. It may be d charger or d port......
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rajesh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 317
