跳转到主内容
Cannot erase format install OS
Old hard drive failed. Ordered new Toshiba 320 GB hard drive and installed. Attempted to install OS X on new drive. Cannot erase or partition drive. I get the error: Cannot Allocate Memory.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Check your SATA cable connections - it's possible you may need to replace the SATA cable if you damaged it taking out the old HDD.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
2条评论:
Thanks... I was very careful with the cable during the fix....but I have ordered new cable. We'll see what happens. Hoping, at this point, that it was/is a bad cable originally...that way I end up with an extra HDD.
完成的
It could be - others have reported that sequence of events... if you have an extra working drive you can not return put it in an external case and use it as a backup drive.
完成的
添加一条评论
添加你的答案
wdneighbors 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 126
