跳转到主内容
加入维修社区 - 创建账户
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
Restarts every 3 seconds (bootloop)
Hello,
So I tried to repair an iphone 4s with some sort of "bootloop". It restarts every 3 seconds... ( https://www.dropbox.com/s/djk0eclmz4ognz... ).
I changed the Dock connector, I tried a new battery and tried to restore with DFU (error 4005).
Tried Restoring IPSW with redsn0w. No luck..
Could someone help please, I am out of solutions...
Thanks
Michael
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
I had a similar problem with a 4S when I replaced the power/proximity sensor cable. Once I had replaced the cable and reassembled everything, I turned the phone on and it would freeze at the apple logo and sometimes enter a bootloop. I started inspecting the circuit board for damage but couldn't find anything that was apparent, and then I tried unplugging the power cable/proximity sensor. With the cable unplugged, I started the phone by plugging it into a USB cable and it worked perfectly!
So I would try starting the phone in that same manner to test the different components. It is possible that a bad component other than the battery or dock connector can be the problem.
这个答案有帮助吗?
得分 0
1条评论:
Tried to unplug every component, still no change..
The iphone flashes the apple logo (https://www.dropbox.com/s/djk0eclmz4ognz...). Could this be a problem with the Gpu or something?
Thanks
完成的
添加一条评论
I have a samsung galaxy tab 2 10.1 thats doing this same thing. I bought and replaced a new battery, and charging flex cable and still the bootlooping remains. Many have told me that samsung is aware of this issue and it can't be fixed if it wont do a soft or hard reset. Im at a loss. VERY frustrated.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael Maeter 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 356
