跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 个问题 查看全部
问题已关闭
Replace bluetooth module with bluetooth module supporting bluetooth 4
Hello there. I have Macbook Pro Mid 2010. Internal bluetooth module in this model does not support Bluetooth 4. I would like to know if I can find some internal bluetooth module which will support Bluetooth 4 and will be compatible with my Macbook.
I was looking on the internet and found nothing. I was looking on bluetooth repair guides of newer Macbook and BT modules look same. But that's only look. So if anybody knows about internal BT4 module which would be compatible with my Macbook that would be great. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Your unit has the following: AirPort Extreme (802.11a/b/g/n) and Bluetooth 2.1+EDR standard. Here's the IFIXIT guide to see how to replace it: MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board Replacement
You'll need to find a Mid '12 15" MacBook Pro AirPort/BlueTooth board which is the same size and offers Bluetooth 4.0 services. But, it offers MIMO WiFi (3 antenna Vs 2) so the WiFi services won't work correctly unless you swap out the display assembly as well (it has the antenna). Here's the IFIXIT guide for this model: MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Board Replacement.
You might consider looking for a used Mid '12 MacBook Pro system and selling yours given the differences.
MacBook Pro 15" Unibody Mid 2010 AirPort/Bluetooth Board图片
指南
难度:
中等
30 - 45 minutes
MacBook Pro 15" Unibody Mid 2012 AirPort/Bluetooth Board图片
指南
难度:
中等
30 minutes - 1 hour
这个答案有帮助吗?
得分 2
4条评论:
Thank you very much for quick and accurate answer!
完成的
If this answer answered your question please remember to rate (score) and mark it accepted.
完成的
I have the same question but in my case it's about a early 2011 MacBook Pro 13" (MacBookPro8,1). Will I be able to use Handoff/continuity if I install the card that you sell online (MacBook Pro Unibody (Early 2011/Late 2011/Mid 2012) Airport/Bluetooth Board)? Is it this one: BCM94331PCIEBT4CAX 607-8958?
Thanks for your reply,
Andrei
完成的
antintu - You should post your own question and you may want to review some of the other answers as this has been asked a few times. Review this site Continuity Activation Tool
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,013
