跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
Why won't it turn on after battery replacement?
The 5C came to me with a shattered screen. I fixed the screen and it would not turn on. I tested the screen and it works on another 5C. I replaced the battery. The battery works on another 5C. I have tried holding the home button and the power button to reset it. That will not work. I have plugged into the computer. Will not charge. The working 5C worked on the computer. I tried plugging it into the wall. The wall charger worked on the working 5C. What else could possibly be wrong with this phone?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
6个答案
Have you tried DFU mode and then itunes?
Try to hold the power and homebutton for a really long time (like a minute or so)
这个答案有帮助吗?
得分 0
添加一条评论
Had this same problem and The phone is still just sitting
这个答案有帮助吗?
得分 0
添加一条评论
If it was working before a screen replacement and now you have no power, I would be looking for a missing/damaged component on the board near the battery connector.
这个答案有帮助吗?
得分 0
添加一条评论
I had a similar issue, our IPhone 5C will not turn on. I tested the battery and the screen on a second IPhone 5C and both worked. All connector are secure. I'm searching for an answer to this problem.
这个答案有帮助吗?
得分 0
添加一条评论
Did anyone find an answer to the above question?
这个答案有帮助吗?
得分 0
添加一条评论
I had the same issue, try DFU mode and restore with iTunes, after that the iPhone will turn on. But if you have the battery at 0% and turns off the issue can happen again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
keldavis5 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,019
