跳转到主内容
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
1233 个问题 查看全部
Where is the Wifi Antenna on a 5C?
I recently repaired a 5C, doing my first screen replacement on one of these models. Replaced the screen and LCD assembly completely, bringing over the old home button, camera, earpiece, etc.
Now I have no wifi. The wifi is greyed out in the menu, and won't turn on. I believe I accidentally bumped the wifi antenna, but I don't have a clue- where is it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
I can't see the Ici but ICI see the imei is and my Bluetooth don't work along with my phone saying not service
完成的
添加一条评论
2个答案
已选择的解决方案
This is the wifi anntena here and it plugs in under the motherboard if you only changed the display then you would not even be close til this part .
I would try a restore first to rule out a a bug in the system if it's still greyed out after then you have damaged the motherboard in someway
这个答案有帮助吗?
得分 3
添加一条评论
Sounds like somehow the wifi / Bluetooth IC chip got shorted.
Most likely when doing a screen replacement without battery plugged in.
Most likely your Bluetooth does not work as well.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ian Dalsin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 7
总计 6,916
