跳转到主内容
The Sony Ericsson Xperia Arc S is a phone with Android 2.3.4 featuring a a 1.4 GHz Snapdragon CPU and 14.4Mbit/s HSDPA.
11 个问题 查看全部
Cannot turn on device, charging or not
When I press the power button, the unit sometimes can be turned on, sometimes not.
Recently, it is totally dead. Even I have a fully charged battery or connecting to a USB cable, the unit has no response to the power button.
No red light when I charge the unit as well, i.e. the unit won't charge.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
1个答案
最有帮助的答案
Hi,
If the battery voltage is OK then clean the battery connectors. Check what happens when you connect it to the PC. Connect the device until you hold the Back key (down left key). If the windows see the device in the "Device manager" then may be you have a software problem.
Try a Hard reset. Press and hold left and right buttons under the screen. Press and release the Power button. Follow the instruction for a hard / factory reset.
!!! This will erase all your data !!!
Next, you can try SW update with the PC Companion or directly with the Sony Update Service.
If you haven't reaction from the windows for connected device then yo have a hardware problem.
Regards.
这个答案有帮助吗?
得分 3
2条评论:
Thank you very much for your advice. It is very appreciated.
device manager cannot see the device. guess it is hardware problem. anything i can do?
完成的
No, you need a mobile phone specialist :(
完成的
添加一条评论
添加你的答案
Peter 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 17
总计 7,773
