跳转到主内容
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 个问题 查看全部
问题已关闭
iPad2 Screen very dim to view
Faint resolution or display of graphics about 10% brightness I have reload OS 7.1 still same. Lower right corner of iPad slight indentation
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
I would strongly caution you against manipulating the LCD while plugged in---if the cable becomes dislodged from the connector while the device is under power you will certainly blow your backlight fuse.
What is the history of this iPad?
If any chance of water damage, my guess would be backlight coil
这个答案有帮助吗?
得分 2
添加一条评论
Your information is real limited, The Ipad 2 has a problem with the LCD Cable that can cause these symptoms, I would start by removing the Digitizer, then the 4 screws that hold the LCD in place,, with the Ipad powered on carefully lift the LCD while it is plugged into the Logic Board bending the LCD cable and at the same time watch the LCD and look for changes in lighting and resolution, if there are any you have a bad Cable, replace it, if not you should try a new LCD, good luck
这个答案有帮助吗?
得分 1
添加一条评论
I agree with Mitch's answer. You may also have a slightly disconnected Lcd, which disconnecting and reconnecting the lcd ribbon from both the logic board and the screen itself will likely resolve. The real challenge though is taking your digitizer off without breaking it, the volume/power ribbon, Wifi antenna, etc.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,919
