跳转到主内容
The Nokia 5800 XpressMusic is a Symbian-powered smartphone and portable entertainment device by Nokia.
8 个问题 查看全部
Water Damaged Phone Querry
my nokia 5800 xpress music got drowned in a mug of water for 3 to 7 seconds. now its not working. initially it was working a bit like its three bottom line buttons were glowing and it was able to switch on with no display. but now its not even switching on and the three bottom LEDs are also not glowing.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
When you have a water damaged phone you must do this:
- Remove the battery and don't try to switch-on it.
- Disassemble the phone and dry off the water (stay it disassembled for some hours).
- It's good to clean it with an alcohol.
- If you have a magnifying glass, check the mother board and all connectors for oxide.
If this not help you, seek help from a mobile phone technician.
Regards.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Prateek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 256
