跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 个问题 查看全部
问题已关闭
Laptop monitor display has purple line flicker
HI Guys,
I have connected an external monitor to the laptop which proves it is not a graphics card issue. I have tried to reset the P-RAM without success.
I have uploaded an image here
Thank you in advance,
Scott
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Then the symptom points to either the cable or the the display. If moving the screen at all, or pressure on the case changes the lines it's more likely the LVDS cable.
If this answer is acceptable please remember to return and mark it.
这个答案有帮助吗?
得分 1
3条评论:
hi Machead, it doesn't seem to be the cable, very weird.
完成的
LCD's do go bad, get damaged. What year is this machine? Has it been dropped or had anything stacked on it, or squeezed in a case or compartment?
完成的
Yes, it was dropped in 2010 and has been fine since. It was built in July 2009.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,079
