跳转到主内容
The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
120 个问题 查看全部
Why is my samsung galaxy tab 3 always shutting down?
While using my galaxy tab 3 or even when standby in the homescreen, my tab will eventually shut down. It won't turn on again until I press the power button. It always happen. Can anyone help me solve this problem? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
6个答案
i have the same problem why?
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem how to fix it
这个答案有帮助吗?
得分 0
添加一条评论
Does it shut down when it's plugged in, or just when it's unplugged? If it works plugged in, then you need a new battery.
这个答案有帮助吗?
得分 0
1条评论:
it shuts down in both the cases.
完成的
添加一条评论
I have a problem wirh mine stop responding with games all the time, found that these tables are just a piece of junk, even though I paid to much, I am considering a better tablet of a different brand, and am deffenately going to contact samsung with a complant.
这个答案有帮助吗?
得分 0
添加一条评论
bad design
power supply bad designed
batery bad designe
in other words trohw it in to the garbage and buy a new one
这个答案有帮助吗?
得分 0
添加一条评论
Hi! If there is a bad electronic component, like a device in short circuit, it will try to start and detects the short, and turns off. If there is a defected charging circuit, it will happen the same or to show dead after a total discharge. OR, and "AND" the last ones, plus if the battery is under the operation level, some models of tablets are not able to start. First step is to charge the battery and to see if the tablet is able to start and charge, or if there is a bad component because there is a wrong behavior.
The following video was recorded for technicians with this kind of problems: https://www.youtube.com/watch?v=2ggQU3E0...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jelaine Bernardo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 1,415
