跳转到主内容
加入维修社区 - 创建账户
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
iPhone5 won't restore (error 2001) after screen+battery replacement.
Hello I got a screen replacement for iPhone 5. After I connected the screen I got a white line across it. I read it is due to battery getting disconnected so I reconnected the battery. Got even more white lines.
After reconnecting battery / screen several times I finally got the iPhone to boot without white lines.
Except this time it was a boot loop.
I tried restoring it via iTunes, but no luck.
The iPhone will also not start without USB.
iTunes gives error 2001.
iPhone is not jailbroken.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
I'm going to guess pry damage behind SIM tray on motherboard---but mostly because I fixed nine phones with that problem today :)
If a component called U3 is damaged the home and power button will not work and phone will boot to recovery mode. Fix = replace U3
这个答案有帮助吗?
得分 2
2条评论:
And what is the cost of replacing a U3 please?
完成的
Or just try a different battery. The connection between the battery and motherboard may not be secure.
完成的
添加一条评论
battery is not giving proper power in logic board
so only change the battery and solve the problem
这个答案有帮助吗?
得分 1
添加一条评论
Try this www.support.apple.com/en-us/TS3694.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
zzzbog 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 8,956
