跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 个问题 查看全部
Anyone tried removing/replacing individual keys?
I have a client with a "sticky" spacebar. I am hesitant to remove the key for cleaning for fear of either breaking the key/assembly, or not being able to get the key back on properly. I've done this countless times on previous models, but give the uniqueness of this machine I thought it may be beneficial to ask first. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
No different than the others.
Apple so far has removable key caps (including the space bar) across all of their laptops so people can swap out the caps for a different language set.
Here's a good Youtube on how: How to remove and clean Macbook Pro keyboard keys
Hope this helps
这个答案有帮助吗?
得分 4
添加一条评论
Tried to remove the backspace, enter and shift keys and resulted in the clips breaking and have to order new keys.
Hope this helps
这个答案有帮助吗?
得分 2
3条评论:
Where did you order your individual keys?
完成的
Give these folks a try: TheBookYard
完成的
Thank you Dan for sharing this info and geni499 for asking.
完成的
添加一条评论
添加你的答案
Grillwrecka 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 30,580
