跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
iPhone 5s will not power back up
Iphone 5s was submerged in salt water. It was removed from salt water and rinsed/submerged in fresh water to hopefully get rid of salt. It then placed in container of rice for several days. Will not power back up or indicate charging when plugged in. Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
take the board out following the ifixit teardown, once the board is out clean it using alcohol solution(not vodka) then hope leave to dry, put the board in and hopefully it will work, but if anything is corroded or damage, it may need more work
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Think u just put the nail in the coffin when you tryed cleaning it with water lol
Rice is the worst thing you can do I'm afraid phone needs cleaned out with alcohol and dryed..
When water drys it causes corrosion drying a iPhone out in the worst thing you can do
这个答案有帮助吗?
得分 1
添加一条评论
Need new battery for starters. To check if it is still alive, disconnect battery, then connect to lightning power to see if screen responds.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
paul 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 359
